查看: 8313|回复: 1
论坛依然活动量不大
小学生
热心会员活跃会员最佳新人
发表于 2014-7-1 08:37:07 | 显示全部楼层 |阅读模式
ROS 6.15版本有个 ip--Cloud 这个上面的DNS-name 能不能改,那么复杂不好记,还有6.15版本的changeip更新只检测升级但是就是域名解析不了这个IP
没有谁比谁厉害,只有谁比谁热心!
发表于 2014-7-29 08:55:38 | 显示全部楼层
我用着挺好的,每次都能正常联接,下面是我用的脚本
:global ddnsuser "你申请的用户名"
:global ddnspass "密码"
:global ddnshost "免费二级域名"
:global ddnsinterface "pppoe-out1"
:global ddnslastip
:global ddnsip [ /ip address get [/ip address find dynamic=yes interface=$ddnsinterface ] address ]
:if ( [:typeof $ddnslastip]="nothing" ) do={ :global ddnslastip 0.0.0.0/0 }
:if ( [:typeof $ddnsip]="nothing" ) do={
  :log info ("DDNS: No ip address present on " . $ddnsinterface . ", please check.")
} else={
  :if ($ddnsip != $ddnslastip) do={
    :log info "DDNS: Sending UPDATE!"
    :log info [ /tool dns-update name=$ddnshost address=[:pick $ddnsip 0 [:find $ddnsip "/"] ] key-name=$ddnsuser key=$ddnspass ]
    :global ddnslastip $ddnsip
  } else={
    :log info "DDNS: No change"
:log info "DDNS: End"
GMT+8, 2026-10-10 03:19 , Processed in 0.191244 second(s), 26 queries .
