查看: 11459|回复: 2
新产品RB3011UiAS-RM
982万
发表于 2015-12-29 11:39:37 | 显示全部楼层 |阅读模式
新产品RB3011UiAS-RM
新产品RB3011UiAS-RM是一种新的多端口设备,基于ARM架构的新款CPU的性能超出以前产品许多。RB3011具有十个千兆端口,分为两个交换组,一个
SFP端口,USB端口采用3.0架构,可用添加移动存储、3G/4G调制解调器。
RB3011UiAS-RM外壳采用1U机架,带有触摸屏液晶面板,一个COM端口和一个带PoE输出功能的网口。
看看配置情况:
Product codeRB3011UiAS-RM
CPU nominal frequency1.4 GHz
CPU core count2
Size of RAM1 GB
10/100/1000 Ethernet ports10
Number of USB ports1
Power Jack1
PoE outYes
Supported input voltage10 V - 30 V
PoE inYes
Voltage MonitorYes
PCB temperature monitorYes
Dimensions443x92x44mm
Operating SystemRouterOS
Operating temperature range-30 + 70 C
License level5
CPUIPQ-8064-0-519FCBGA-TR-01-0
Max Power consumption10W
SFP ports1
USB slot typeUSB 3.0 type A
Serial portRJ45
Storage typeNAND
Storage size128 MB
官方性能测试结果:性能介于850G和RB1100AH中间
RB3011UiAS-RMIPQ-8064 All port test
ModeConfiguration1518 byte512 byte64 byte
kppsMbpskppsMbpskppsMbps
Bridgingnone (fast path)325.03,946.8939.83,849.41,530.2783.5
Bridging25 bridge filter rules325.03,946.8384.21,573.7348.6178.5
Routingnone (fast path)325.03,946.8939.83,849.41,437.6736.1
Routing25 simple queues325.03,946.8419.61,718.7419.7214.9
Routing25 ip filter rules202.02,453.1204.1836.0188.496.5
欢迎联系销售选购。
电话:0755-82642594
GMT+8, 2026-11-14 07:04 , Processed in 0.128162 second(s), 28 queries .
© 2001-2026 Discuz! Team.
